scot w.
GNSperformance.com
- Feb 19, 2005
We have recently teamed up with a Long time,very well known member here on this board that happens to work at a company who manufactures dash's and wiring harness' for Corvette's and together they have already made up several samples of dash designs for our Regal's at a reasonable price. The company who makes these dash's actually has places like Ecklers and Corvette Central selling their products so this place does fantastic work and is very reputable.
Cost will be in the mid $800.00 range for everything!
Keep in mind that some cutting of a Dremel will be required! You still have to take your dash cluster cradle and modify it to fit the new gauge panel. Pretty simple to do though...
Each dash will come with:
* Autometer gauges (Your choice of ANY gauges can also be installed)
* LED indicator lights (Also available are LED sequential signal indicators for those of you with our GNS Digital LED taillights)
* ALL Sensors (Including the VSS)
* Pre-wired & tested
* Wired with Caspers style plug to plug into your OEM harness
Each gauge panel will have a couple gauge placement/orientation designs to choose from to suit everyone's needs. We are pretty much going after the design of my personal dash that I had done over 5 years ago which incorporates pretty much every gauge you need all located nicely in one place all which is very visible.
Below you can see our GNS hidden tach bracket with the Alky controller mounted to it...
Stay tuned as information and details come in I will post them up... Order time should be in a couple weeks!
