turbowannabe
- Dec 6, 2001
Hey guys,
Well I just bought a 1987 GN hardtop that now has 93,000 miles on it after the drive home from florida. The car is in pretty good condition, with the only major imperfections on the drivers side. But I'm not really worried about the exterior, it looks fine for what it is now. The car runs top notch when it's up and running, but kind of stumbles at idle and a little when I just press the pedal lightly to get the car going. After I get up the rpms a little bit or the car gets up to higher temp everything is fine. When I bought the car the check engine light came on and the guy showed me the code 44 that the scanmaster was picking up. He told me it was a rich code caused by the 50lb injectors, and if you let the car sit at idle too long it would set the engine light but would turn off after you got driving. He took us on a ride and sure enough the check engine light went out, but still showed code 44 up till yesterday when I reset the computer. Now it hasn't come back.
The car has been running really cold( runs in the 130's and 140's unless I let it sit and warm up someplace, but stays cool when on open road), probably due to the obvious temperature difference between florida which was 86 when we left and it is now in the 30's here. My target temp area would be around high 160's low 170's. I'm thinking it's the 02 sensor, since it will go to all zeros if i'm driving and let off the gas, and when accelerating it goes between .020 and.090. I still don't know exactly how to read it but i've been learning, shouldn't it bounce from really low to really high to show a rich to lean condition idicating an properly operating 02 sensor? Plus the blm is pegged at 150 most of the time. Here's what my scanmaster has been showing at idle
02 volts- has been really wierd, kind of explained it above
tps- 42 just about perfect
Maf- 4
int- 149
blm- pegged at 150 most of the time
lv8-30-36
Iac- 9-11
I forgot to mention I also have underdrive pulleys and a Joe Lubrant chip
I'm going to go buy a new oxygen sensor and IAC tomorrow, am probably going to buy a 180 thermostat to get things back up to temp, and I already bought some replacement vacuum hose ends today, and am planning on doing a full spring cleaning this weekend. Does anyone recommend using engine flush?
What are all the functions of the scanmaster and how to I read it. I'm learning a little but I'd like to know as much as possible. I read that the numbers the scanmaster reads are different between whatever chip your running, is that true? There's a few more readouts than the ones i listed, besides the obvious ones like mph and rpm and temp, i think one is intake air temp What should I keep knock below? Does any of this look abnormal to you? Let me know what you think
thanks
Dan
Maf- 4
int- 149
lv8-30-36
Iac- 9-11
thanks
Dan
