national86
- Jan 26, 2004
I am having BLM problems with my 86 , the car is popping under boost .I have check and replaced vaccum hoses , replaced charcoal canister sol ,EGR valve, ERG sol and Heater water valve. I ever sprayed carb cleaner around TB, vacuum block ,every place I could think of and nothing. Fuel Press is at 45psi vac off ,has KB ultimate chip in it. Now that I changed all those parts, when driving and I come to a stop, it feels like it is going to stall and hesitates when I take off. It did not do this when the old parts were in it. The old parts did not hold vac with vacuum pump. Stock chip does to same thing.Computer was reset after new parts installed. please help
Scan Master readings at idlestock chip)
Af-03-04
L8-25-26
Bat-13.6
Int 124-132
bl- starts at 128 and slowly goes to 150
Mph-0
Clt-190
Ats-143
Rpm-725
Tps-.44
Iac-30-32
Af-03-04
L8-25-26
Bat-13.6
Int 124-132
Mph-0
Clt-190
Ats-143
Rpm-725
Tps-.44
Iac-30-32
