Yeah that looks like a cool radiator as long as you can figure out how to extend the oil cooler lines.
I'm still really happy with the F-Body I threw in. I can drive 35 miles, all the way home from work, climbing up hills through a small mountain range, and my fan doesnt even turn on cause it wont go over 170 degrees. The highest its ever reached was this morning...181, and I was sitting in traffic that wasnt moving in this early summer heat. I had to cut the steel tube ends off the oil cooler lines, run my own hose, and loop it around to bypass it. So no oil cooler and it still runs really cool. This radiator has the tranny cooler lines, but I dont use them cause I had put in an external tranny cooler the week before the radiator. I thought of using the tranny cooler in the F-Body radiator as the oil cooler, but those lines are way smaller and figured it may be a major oil restriction, so I just bypassed it. The radiator is a direct drop-in. No mounts or anything had to be moved like someone was saying.
God bless the guy who first discovered that this F-Body radiator worked!
