NGK UR5's for my setup?
Renthorin
Lone Wolf
I am going to give them a try this plug change.
I have a stock turbo, stock injectors, 93 street chip, SMC alky, and run about 22 lbs of boost.
Are the UR5's going to be ok for me? Do I gap them at 31 or 35?
TIA
We've found that Autolite 23's work best when you run 11.80 and quicker and 24's if slower than 11.80.
HTH
Jim
Hey
these are really nice plugs and id recommed them gap at 35 and see how you like them if you dont take them out
Johnny
I personally didn't see a difference between the NGK's and AC Delco's. I wouldn't waste my money on the plugs unless you are faster as stated above.
Dannyo
I like the UR5's, every one that comes out of a box is perfect I like the percision. I sure haven't found that w/ the autolites or AC....they sometimes have electrodes bent all over the place but I also haven't ever had a problem running any of the 3 types just like to see a quality plug.
Ok..... my local shop had the plugs for me so I grabbed 6.
They don't have the little crush washers I was expecting to see.
Is this normal? Should I follow the tq suggestions when tightening them?
I ended up getting a set of Accel u grove plugs before going to the track for spares incase something stupid happened with the Nitrous . Ill tell you guys for some reason i can now run 19psi of boost with my Reds chip wo knock where before i could only do 16 on pump gas :confused: The plugs was the only change . They are made by the Nippeenso or whatever i think they make the NGK i could be wrong .
