No BLM 150-went Down after unpluggin MAF
V6Turbo
3" ATR Dual Exhaust, THDP, Walbro 255-Hot Wired, 9
All,
I think I found my problems with High BLM-143 to 150.
I unpluggged the MAF Sensor and went into LIMP mode. The BLM's went down to 123~128. Is this is a good confirmation that the MAF sensor is the root-cause to my High BLMs'
Can the MAF still be a problem even if the scanmaster and stays around 5 to 6?
Thanks in advance.
MAF # should be 5-6 gps in park.
Make sure you have the correct MAF: connector should be 90* from the MAF cylinder. It should say AC on it meaning AC Delco.
I don't think a 128 BLM with MAF unplugged means the MAF is to blame necessarily. Without the MAF plugged in, the ECM has no air metered. The LIMP mode may use a 128 default.
Best thing to do is swap with a known good MAF, and that way you've eliminated it as a suspect.
