No Electric!!!
dmk2
I have an 86 GN - Stock.
The other day I went out and started the car. It ran while I milled around in the garage. I get in to back it out and it cuts off. I jiggled the ignition switch and the indtruments go on and off. I have taken the entire stearing collumn apart and replace the key tumbler and the ignition switch that is down on the collumn, still no change. The bell goes off when I have the door open, but when I turn the key it goes off. Turn signals do not work but the headlights do. The radio does not work either.
If anyone has any suggestions please let me know!
Thanks,
Daniel
If you jiggle the key and things flash on and off, it's still in the ignition tumbler or switch. If it's just dead power, it could be one of the fusible links at the starter.
