no longer have park?
Louster38
so i had my car up on stands to work on the rear end. had to replace a broken nut and an axle. sometime during the process of putting the trans in neutral, park, and drive while it was up there, something must have broke, because it is in park right now, but i can move the rear tires (its still up on stands) so what did i break and how do i fix it?
If you spin the one wheel, does the other wheel go in the opposite direction?And if it does can you stop it and still turn the one wheel? If you can't then the park gear is still working. Let it down and try to see if it holds in park.
yeah, that is the case. looks like i still have park, i just didnt remember being able to move the wheels at all when it was in park before. guess im losing my mind.
