i know this has been covered alot on forums
but this one had me pee dazzled last couple days
working on 87 t
car has new coil pack module
complete new cam sensor and cap
car was brought to be becouse it would not start
guy said it would fire sometime
then sometime would not
i got it here and seen they never replaced crank sensor
put one on car and it fired up and run
started car id say 5 or 6 times within a hour
was checking out everything, tried to fire it again, no fire
checked crank sensor and it touched balancer a little
though it might of messed up sensor
so took balancer off checked for bends ect on balancer window was ok
took cranks sensor back exchanged it for a new one and stopped for the day
today tried to start car again
no fire
car has new crank sensor
coil pack and module that i know is good
car has new cam sensor and cap
i checked it, its set 25 degrees after top dead center
but did not take completly all the way out just checked it with tool
all ground are good clean and tight on back of head
ecm plug ins are all good ect
was messing some with it before i come home this evening
with a couple wired pulles off coil pack
tried cranking a few times
i did get fire once bouncing off terminals
next time nothing
going to work on it some more tomarrow
and ideas anyone?????
working on 87 t
no fire
next time nothing
