ttypewhite
- Oct 1, 2001
The car ran fine. Then got hard to start. Then would not start again. I changed the cam sensor, crank sensor and complete coil pack off of my other GN that runs perfect along with all the fuses under the dashboard (which are fine). I am running the fast Sequential system and under my dashboard setup on the laptop I tried cranking over the car and watching the rpm signal. I do have a signal so that eliminates my crank sensor. Where else can I look?
