No spark, No fuel... HELP!
Robes87GN
Bench Racing Hater
Finally got the trans in, got the motor back together, everything is ready to go. Turn the key over, cranks fine, but no spark or fuel pressure. We had the battery charger running on it, and when we grabbed a loose wire that we had just noticed and touched it to the droplight accidentally, the fuel pump kicked on. Problem was, it wouldn't shut off. I don't know if it needs to be on a kickoff 12v or just to the battery. I have the hotwire kit for it. If it is the battery, I need a new relay, because mine is blown. Next problem... No spark. We can't find a thing wrong with it to cause no spark. All the ground wires are bolted on to the back of the head and everything. Coil pack is on and connected. My friend and I are stumped. Please, anyone that can help, please do. Thanks very much.
Robes
