Hey guys, I've hit a bit of a dead end in my diagnostics and was hoping someone could point me in the right direction.
87 GN - when you turn the key there is nothing not even a click.
Bench tested starter and it works fine. Getting power from the battery, fusible links on the other wires that mount to the constant + stud are ok.
No signal at the switched ignition wire that mounts on the small stud on the solenoid. The purple wire from the ignition switch is getting 12v. when key is turned.
So what failure points are between the ignition switch and solenoid?
Thanks.
Thanks.
