No start with FAST
FastRegalWE2
Wish I had another Buick!
OK, cam sensor is fine, hooked my Cam tool to it and get the blinking red light, Have spark at plug wires, went and got a noid light and it does not light at all. FAST shows RPM signal of 200 RPM while cranking. Under codes on the FAST it shows 132, I cant find a listing for a code 132. Injectors not firing at all. :dunno:
HELP
edit, checked for power to the injector harness, I have power there from the FAST inj power wire to the harness. I checked the jumper wire from MAP to MAF and it checks good for continuity.
Could the FAST have some how gone into clear flood mode? Maybe thats the Code 132 it is showing???
It was in clear flood mode due to bad TPS
