Non GN fuel tank in GN?
2QWIK4U
Anybody installed a regular Regal tank in a GN.Besides the baffle inside the filler neck looks straighter to me. Can it be made to work?
I'm pretty sure the fit is the same. I have a GN tank for sale if that is what you would rather have.
it lacks the sump box that the pump sits in , without that sump you run high risk of having the pump pickup go dry on at WOT especially if you run the tank level low , the results of running lean will make you wish youd replaced it with the correct fuel injection tank
if your plans are to cut and sump the tank for an external fuel pump sump like the competition engineering then using a NA tank wont make any difference
