Hey Guys, I need some help. I went to go pick up my car from the paint shop and it wont start. Its not getting fuel. When you turn on the key, you normally hear the car pressurizing the fuel system. Well, there is no sound. I changed the fuel relay and that didnt work. When I brought the car to the painter, we took off the bumpers, door panels, etc but thats about it. The fuel pump has a connector that was screwed onto the rear bumper ( which was painted on the back side. I ground the area down where this connecting block screws onto, thinking that block may have to be grounded but that didn't help. Does that even effect anyhting? I am clueless where else to check. Is there some connector that may be disconnected? Is it the ECM, fuel pump, or something like that? I checked the IGN/Fuel fuse and its fine. Any idea where to start to dig? The huel pump is a fairly new Walboro so I woldn't think that would be bad. It has a Hotwire kit but I didn't see anything loose. PLease help I need to get this car home. Thanks a lot guys!! -----Jeremy
