not "melissa fast" but getting there slowly
Your 60's are mint dude.......Is that off a transbrake? If not that is truly awesome!!
Nice work and def on your way!!!
Nice times!
Are you launching off a transbrake to get those kind of 60' numbers? What boost were you running?
200-4r with stageright brake
on beat up 275/60 MT radials inflated at 22psi
suspension is nearly stock
boxed stock lowers
stock uppers
no fancy bushings, look to be old OE
HR parts HD rear sway bar (awesome bar)
stock springs
no airbags
msbc-1 launch was set at 10psi which it holds at nicely
msbc-1 timered boost stages were set at 26/25/25 (4seconds per stage) with no ramping but vdo gauge showed only 23psi through third , i have had a second boost gauge installed and i tend to beleive the VDO is accurate
the tbrake is mechanical (engages at L1) but i have i have a leaf switch on shifter mechanism (from old MSD two step) which engages at L1 and allows 12v to pass through switch to engage the msbc-1 launch mode , rather than rig another switch i tied into that 12v switched line and connected a relay using it to ground the violet wire of the alkycontroller which lowers alky spray until the brake is released . before using the violet wire the alky would kill the 60ft by drowning the motor when trying for launches at anything over 6psi because of the dual nozzles .
I got to try that purple wire thing :eek: .. Great job as always.. you smoked your race gas best..
Thats one bad ride on DR's :D
PS.. careful giving Grumpy ideas ya know :eek: ;)
:) we have plenty of ideas................It's getting them by the queen that's the problem.........
We have her talked into bigger tires...........We wanted both the brake and the tires.........We got 1 of the 2 and believe me, we'll take whatever she gives us.
ya I am reading :eek: trying for next sat @ CC ... well providing it's still running :biggrin: taking a 5 hr ride with it wed :cool: drove it today in a little snow :eek:
No
block is a 109
bottom end is stock , crank- rods- pistons , no mains or girdles or studs, looks to be stock bolts too
heads are stock 8445 irons , ported by national performance (former owner ) , not sure on specifics
no roller, cam i'm told cam is mild , 212/208 hydraulic flat tappet possibly an old precision grind , rockers are stock (broke a shaft a few months back)
head gasket looks to be rjc's and they are studded
oiling is run through PTE turbosaver
intake and exhaust manifolds are stock
plenum is MPE (keith mease) sheetmetal
tb is accufab 70
fuel system is an ATR intank double pumper with new 340 pumps hotwired , stock lines
75# msd injectors with rtx hotwire harness
i run a stock 7148 ecm (modded for injectors of course) and TuboTweak chips which need a MAF , so i run a translator + ( spark control not hooked up) and have a 3" LT1 maf at oulet of intercooler
turbo has an old compressor housing70-1 A/R 4" in 2 1/2" out , air enters through a 4" steel chromed mafless inlet pipe with a 4x9 KN on the end (in summer i run it cold air style through headlamp opening to under car ), exhaust housing is 3 bolt .85 A/R precision ported 1.5" at wastegate for external pipe
I/C is old tony dequick CAS V2 with 2 1/2 inlet pipe and 3" outlet pipe
downpipe is old ATR 3" external and outlet to DP ported to match turbo and 'jersey dump'
boost controlled with MSBc-1 boost contoller and 5psi spring in HKS gate
i have a QTP cutout on the dump end but all but the 4th run were done closed though full exhaust
exhaust is terry houston stainless 2 3/4' duals with stainless magnaflows
ignition is stock gm coilpack and ignition modiule with MSD DIS-4 ( besides the capcitive discharge at low rpm only DIS-4 feature active is 6250 rpm limiter ) and MSD 8.5 superconductor GN wires
alky injectoion is none other than alkycontrol with dual nozzle spraying 100% VP M-1 methanol. gain set at mid point
has champion alt /ps bracket (deletes a/c compressor and tensioner assembly)
cooling is f body radiator with valeo dual fans RTX hotwired
AC box is removed with a mark huefman plate on firewall but i plan to reinstall either an ac box or the heater only system to get some heat in the car , it was a cold drive to atco , only 26* in the car
trans is worked 200 but not full billet , has deep PTE pan , shifter is stock
converter is oldschool art car 16930 3600 9" non lock, BMS flywheel sfi blanket, big B&M trans cooler
driveshaft is built HD chro-moly with spicer yokes and non greaseble ujoints
rear is built 8.5 GM with 3.42 . moser spool , 33spline axles, eliminators, and arp studs)
finished off with token CF hood and stock appearing bumpers 6 point roll bar (no swingouts), rci belts , eibach front springs
and VDO 8gauge gnx dash (with casper knocksensor), scanmaster , smc egt and directscan
Maybe she'll give in on the transbrake after seeing those video's. Very nice 60'. I'ld like to have a 60 like that.:(
congrats
That is incredible. I gotta get in on this stuff. Wow I feel like a fool. My car is a yugo compared to this. Keep up the great work :)
No
block is a 109
Your my Hero :D
keeping things simple pay's off !!!!! :biggrin: Are you goin to the track anymore this year ???? ya know ... push a little more :p looking great !!
on another note NO brake for her ... She said she WILL get it straight with the footbrake :eek: :p
i would like to make another , maybe cecil :),
car is overdue for a converter freshening , looks like 15% slippage , trap at 5900, i did make the 10.48 pass in OD (missed 3 on the shift and car shifted to 4th at 5550rpm at 543ft ,trapped at 5450
i had my o2s drop out once i hit third gear on the last two passes and only change was adding some fuel because the sun went away and temps had dropped , (had 1760-1780egts when previous runs were 1550-1600) and heat may have had an affect on the o2 sensor , no kR dispite 670-690 readings
so either i was rich and ignited in the exhaust pipes taking out the sensor or i have a fueling issue, maybe lost a pump , need to inspect and test all the relays to the pumps and the filter
Dang... That thing scoots. :eek:
Might be going to Cecil huh ? :D
[mumbles to self]My car is parked for the winter...my car is parked for the winter...racing season is over...racing season is over[/mumbles to self]
[yells at youllose] cecil is still open and the racing season is not over.... Need to hook up blue bottle and go down the track one more time [/yells at youllose] :biggrin:
Pauly as always is flying... I cant wait to see both Pauly AND Art at cecil one more time this year :eek:
