Seeing oil at my plate (and in the lines, vac. block, etc)!! Not a ton, but enough to make the tb a little sticky and "coat" the entire housing.
I did a search and went through a ton of good post concerning pcv function, but I haven't found anything pertaining to whether or not the ATR pcv replacement is worth it....more important, is it causing a problem that I'm unaware of (besides letting oil by)?
Street driven (<1000 miles a year) and it is set to run 22-24 pounds of boost.....which is why I upgraded years ago to what I was told is the "better" alternative to a factory pcv valve.
Now, I'm starting to think that either this valve needs periodic rebuilding or something else needs to be done.
How are you guys setting this up??? No pcv doesn't seem like a good alternative (according to search)....so what do I do now? I don't see as many posts anymore concerning problems with pcv, so it must mean there is a good fix.....is there???
....gets me excited to think that I could be having knock from this...which means I might be able to squeeze more out of this baby
