turbowannabe
- Dec 6, 2001
Hey guys,
Some of you may have seen my other post which I was trying to figure out my BLM's of 150 and a sudden surging and very poor gas mileage I got with my car. Well I figured out that it was a exhaust leak at the turbo exhaust entrance. I'm currently waiting on my parts to come in from ramchargers then it should be all set to go. The only thing is, when I first drained the oil the other day it looked a little light in color and possibly some seperation of fluids in the oil. I freaked out for a minute and thought that I blew a headgasket to boot. But after a minute I thought how I was told/read about these exhaust leaks, high blm's and so much fuel being dumped in that it would work its way into the oil. So after that I kind of ignored it thinking I was just getting myself worked up about nothing.
Well when I got done with the oil change, I added five quarts and the oil shows up just at the bottom of the crosshatches(I also put the larger pf52 filter on). So, I add another quart and it's right where it needs to be. (I also checked the oil on the 1200 mile trip getting the car here from Florida noticed the same thing; oil exactly a quart low on the dipstick so I added a quart thinking it only had 4 quarts and then it went right to the line.) The only running the car has done is idling for maybe a total of 15 minutes in my garage with all the intake parts off and maf disconnected. Well last night I got to thinking that I needed to drain that extra quart out so that I mess something else up, and when I do it looks like the other oil did when I drained it, and like I said the oil only has like 15 minutes of idling on it. So now I'm getting paranoid again thinking a HG may have blown. Do I have anything to worry about or is it just the old oil mixing with the new and messing with me? What should I look for, shouldn't it be obvious if I have a blown HG? I started it up and let it run more today and saw no bubbling out of the radiator with the cap off, no white smoke out of exhaust, and the oil on the dipstick looks good compared to the oil I drained out. Let me know
thanks a lot
Dan
P.S. sorry for the long winded posts but I try to get as much info on here as possible.
thanks a lot
Dan
