Hi : I am new to the TR circut and just recently purchased an 84 TR. The previous owner had the motor rebuilt & I noticed a few things
1: The dip stick is coming out from the pan between the 2 and 3rd exhaust ports.The stick tube has a horseshoe shaped brcket that I guess attaches tothe manifold nut. however it appears that it should be coming up from the 1st and 2nd port so that it attaches to the 1 or 2nd manifold bolt. right?
2: on the same driver side I noticed a ground wire that is only attached to the fire wall. where does the other side attached to?
3; there is a bracket containing a bunch of lines that appears to have been attached to the bottom back valve cover bolt yes ,no?
Thanks for the help. Mike
