oil fill gasket?
Vendor Defendor
Out the window
i noticed today by my oil fil cap that there is oil all over the place... after some inspecting we found that the gasket is pretty loose, so i figured that i would start off fixing this by replacing this gasket...
does anyone have a part number on this gasket? and is it a genral gasket or is it 'special' just like our cars are?
i dont know if this has anything to do with it, but i did put a breather on the passenger side valve cover and left and driver side alone... does that have anything to do with it? well let me know...
-neil
Stock driver side breather gasket leaks brand new. Buy the chrome breather from Kirban and extra gasket they last longer.
The original gasket was a hard piece of plastic and was not serviced seperatly. You had to get the tube. The original tube part#25517753 retails for over $40.00 but if you want a cheaper source use part#25519189 from a NA(about $9.00) and swap the gasket. Eric Fisher
