Oil Filter Adapter
GNBeswick
It's just a V6 Regal....
I was looking at the BIGGIE Oil Filter Adapters, but im wondering if they will fit on an 85 GN? I saw them listed at Kirban's for 86-87s only.
The biggie adapter is used on the 86-87's, because the oil cooler adapter is sandwiched on the oil filter mount. That is why it is shaped like a "sleeve" or spacer. On the 86-87, you'd remove the oil filter adapter, and the oil cooler adapter would come off as well. I think the only way the biggie work on an 85 is if you use the sandwich addapter as well, which means running an oil cooler. Hope that is not confusing...
i could not have said it better.
thanks.
GNAsuka, I just got my biggie adapter in the mail the other day, and have the sandwich adapter on the shelf, let me know if you want pics. If you are still running the hot air setup, this would be an easy way to run an external oil cooler, and bigger filter. :D
