Oil - PCV - Intake Gasket - What to do?
Blown&Injected
Any thought on cutting the Intake Gasket to help drain oil away from the PCV?
What is causing the PCV to pick up so much oil anyway?
:confused:
:confused:
This has been beat back and forth several times.I have tried several methods,some work well some not so well.Lately,I am trying the suggestion of putting the PCV in the factory breather tube where the metal tube used to go in behind the turbo.It is baffled and filtered.The nipple that used to plug into the intake gets trimmed off with a hacksaw.Use the aftermarket breather in the driver side.Seems to work good so far and minimizes the hose clutter.I use a small separator to see whats going and it is not filling as fast by far.
going to do a search and read up on it but was thinking that a gasket mod such as cutting the valley pan might be a new idea that I wanted to toss out there for comment.
