So is it common for the oil press. to drop at high RPM say around 4500 to 6000 redline
is the pump cavitating or sucking air from some where
I have the turbo saver from presion turbo and a 1 qt fram racing oil filter
and a huge aftermarket oil cooler
at idle oil press is at 40psi and any thing over that the guage tilts over to 60psi untill you reach that wot in 2nd turning @5000rpm then the gauge slides back to 40/50psi as soon as I lift off of the gas peddle goes back to 60psi
unless im turnning 4500 rpm or better the gauge stays at 60
I have the 60psi spring and the 30% more volume oil pump
20w 50 red line oil
20w 50 red line oil
