oil pressure switch
gn79
I found out that the switch was bad so I replaced it. I noticed that the wires going to it were lose, so I check them out and they were broken and needed repair, so I did. I took them out of the plug to cut and fix them. Now I don`t know which goes were. Can some one tell me were the one with the stripe goes and the gound. Once I know about these two the other one will fall into place.
Look very closely on the plug to see if it is labeled.
The pink/blk wire goes to terminal A.
The Gray wire goes to terminal C.
The ground is the last one to terminal B.
From the manual, too cold to go out and look at the car.
I don't know what condition your connector is in, but GM and NAPA sells a replacement molded connector with about 18 inches of wire. So all you would have to do is splice and use the butt connectors (supplied with the GM part) or solder and use heat shrink.
