I have read the gnttype.org page where it has turbo regal buying info and it states that a car should have oil pressure inthe high teens when the motor is hot and in idle (mine does)its in the 18-19 range my question is what should it be when its hot and in drive? not park. they dont say anything about that in the web site.Other than that the car seems fine.... I am running 10-30 synthetic (mobil-1) and car seems to be at 10-13 when car is fully warmed up. After it has been on the freeway for an hour or so that is when I get that reading of 10-13 psi is that normal or alittle low? I guess if it is a little low I can go to a heavier oil right? any help is appreaciated thanks in advance....
