Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
Can you use the TA oil pump shims only without a gasket? I have 0.0 clearance without a gasket and was planning on using a shim alone. Will I wind up with leaks without a gasket?
Thinnest gasket is .005 and target is .002-.003. May need to go with .005 clearance if I have to use gasket or get machine work done
Any experience with shims alone ?
