I just finished my timing chain/gears-front cover/HV oil pump replacement. I have a question. With the oil pump kit , there are 2 black quater size circular gaskets. I am using the yellow spring in the oil pump. Why do they give you 2 gaskets. Am i supposed to use both or are they different widths to go with the different color springs. Also there was a gray silver dollar size circular gasket that I had no idea where it went. Any ideas?
TIA
TIA
