Had low oil pressure about 2 months ago. Parked the car.
Finally had a chance to remove the oil pan and check the bearings, everything looks great. However, I did find crap ( gasket material on my oil screen ) enough to cause a problem it seems with oil pressure.
I went ahead replaced the oil screen( new Melling ) and re-installed oil pan. Added oil. I have no cooler line adapter so I filled up the filter with oil.
I tried priming the engine but no new oil in filter and I couldn't feel the oil pump gears load up. Removed the oil pump cover. Oil pump gears look ok, no damaged but not a lot of oil came out when I removed the cover.
1. I need to pack the gears and cover with petroleum jelly, right?
2. As far as the spring and relief valve, how do I confirm they are not sticking open/close?
Pretty sure the oil pump went dry when the oil screen was plugged.
But like I said I haven't seen any damage anywhere.
