? on install of oil pressure VDO gauge
Steves87
Just got the VDO oil gauge today and it looks like there should be more to it. Does the Kirban kit require parts to be bought seperately? I have never installed any gauges before but figured it cant be that hard. There is no wiring, etc with the kit. Do you use all stock wiring.
well, you also need the oil pressure sender. you have to remove the factory one and replace with the vdo one. then you just have to run i wire from the gauge to the sender. very simple:D
