Ok after going through some repair on the car i thought i had everything settled as far as knock, my fuel pump is good pressures good, running 19 in of vac, my car is set at 15 psi. and static fuel pressure is at 43 psi. but im still seeing 7.3-13 degrees of knock and its not nessecarily at WOT. the turbo also is acting weird ill see like 14 pounds then itll drop to like 11 then raise slightly
Idle wot
02 820 785
af 6 255
l8 45 255
int 128 121,this is whats weird ive seen 118-156 driving around
blm 127 123
tps .42 3.7
iac 26
rpm 825
Idle wot
02 820 785
af 6 255
l8 45 255
blm 127 123
tps .42 3.7
iac 26
rpm 825
