Why does my car only build 20psi? I can set the wastegate actuator to 20psi, spin the rod another three full turns, and still only 20psi. Do I need a heavy duty wastegate actuator, or some sort of aftermarket boost control? Or is something else the matter. It seems like the actuator is not capable of holding the pressure, because the car can build 20psi almost instantly at even half throttle. Who carries the heavy duty actuators? Thanks in advance.
