Nighttrain
- Jul 6, 2003
Okay guys, I need as much advice as possible. I have been talking about doing my major timing chain project for a while, and since I have a week off coming up I think I am finally going to do it. However, I am a total rookie at this stuff and I have done a lot of research on this and other sites about what I will need to do this job, ie) stuff I might as well replace since I'm opening up that much. Here is the complete list as far as I've been able to find out:
-timing chain (already have)
-water pump (already have)
-water pump gasket
-oil pickup? (someone said you might just clean the old one)
-oil pan gasket
-rear main seal (mine is leaking and suggested doing this since oil pan off)
-lower rad hose
-crank sensor
-cam sensor
-front cover
-front cover gasket
-oil pump
-oil pump cover gasket
-cam button
-cam thrust bearing
-2 cam bolts?
-teflon thread sealer
-permatex
-carb cleaner (to clean the intercooler while it is off)
As you can see, so far I just have some of the basics, but was about to order the rest of this stuff. Are there any items that you guys think I shouldn't bother with (if it ain't broke don't fix it kind of thing)? On the other side, are there any things I am missing? I certainly don't want it all apart and realize I need something that I have to order, as this is a daily driver, which is why I'm waiting for a week off when I don't need to drive it for a few days. Also, I was thinking of trying to take my time and carefully tackle this myself, I don't have an impact wrench or compressed air, but I am told I can get by without it? Also, are there any special tools that I am going to need? Of course any advice other than this would be appreciated. Thanks a lot guys, I really appreciate your input.
Peter
-water pump gasket
-oil pan gasket
-lower rad hose
-crank sensor
-cam sensor
-front cover
-front cover gasket
-oil pump
-cam button
-cam thrust bearing
-2 cam bolts?
-permatex
Peter
