Opinions of Casper's Ultrachip?
87V6
I am thinking about one of these, the flexibility of multiple tunes is a real plus.
How do these run in your cars? Are the tunes good?
If it makes a difference, I will be looking at an alchy/stock turbo/40# injector setup, if anybody is running something similar to that.
Not sure, but if 40# inj. works like the 009s, then I have one for you.
I went to 50# inj with a single chip and the thumbwheel for the 009s is sitting in a box. Otherwise, I was happy with the wheel...let me play around with different timing settings. I never used 110, so didn't need that high of timing...but I could go up a couple degrees depending on the temperatures.
Let me know if you want one...used for 1 year (less than 2000 miles),
Mark
worked good
Now I'm playing around with a zif socket 29256 on the thumbwheel:) I'll let you know how it turns out!
I had one when I had stock injectors and I liked it. The ability to run 91 on the street w/pos #3, go to the track put in 100 UL and use pos #5. Have the muffler shop install an exhaust and use pos #1. Now I change chips at the track and I think I have broken every stinking clip that connects the ECM holder to the car. :mad:
