Opinions??????
cqk1656
Motor spun a bearing. Took it to my engine builder, he said crank was shot and had already been cut, only parts reusable are the rods..originally was going to just do a rebuild with possible roller cam. But now I figure I will spend the extra cash and get the following:
Eagle crank
BHJ balancer
JW flywheel
JE forged pistons
Billet Roller cam
Champion heads
Ported intake
50lb injectors w/chip
Billet main caps
HV front cover
I have a pt51, FM, THDP, Precision converter. More than I planned on spending. What would you say is a fair price for all this plus machine work and assembly of motor ready to drop in? All work is being done by a well known turbo motor builder....
Just 2 cents
I think that Eagle Crank is going to cost a pretty penny. You can pick up a pristine standard crank from off this board for under $500. Then use the savings for the rest of your goodies. I've been told that unless your making over 500 HP at the wheels your stock crank is good to go. I had one priced to me recently for $450 plus shipping, had never been turned and didn't need it. Good Luck in your adventure. - BB
