Original Down pipe Paint
fLiP650
is the original down pipe on an 87 stainless steel I tried to clean off all the outer rust but can’t get it to shine I don’t like that ceramic coat painting what’s the best paint for the down pipe ?
factory downpipe, just like the headers/ crossover is a 409 stainless. 409 SS is magnetic and will discolor and develop rust over years.
even if you scotchbrite and mechanically polish 409, it will still develop a discolored rust surface over time.
POR15 makes a hi temp paint that looks nice and holds up well. It's the best "cheap" option I have found. Sand blast the parts then immediately paint for best results. Otherwise you should go with chrome ceramic coating with high temperature characteristics.
POR15 paint.
Chrome armor coat....
304 stainless steel downpipe that is polished.
Very nice who does the chrome armor coat for you or you do it yourself?
Yes it's a blend of stuff that gets baked on. It can be polished. I have found coolant stains it but can work at it to remove.
Is the chrome armor coat hi temp ?
Correct, yes high temp. Stays shinny longer on thicker metals I've noticed. Factory headers stay nice for a while but turn dull eventually. Quicker on high HP cars. Aftermarket headers do very well in general. I did a set for my SBC Corvette about 15 years ago and they still look decent.
What brand did you use just so many brands online ? For the chrome armor coat
Try a company called Prismatic Powders. I would call them. A friend of mine is mixing this for me. I don't think it's an off the self situation. You want high heat characteristics.
