Original SD2 tune file
TurboBuRick
Moderator
Staff member
There is currently no way to load the original tune file if it was not saved.
That said I'm looking for the original tune file before any changes were made to the ve table.
TIA
It is stored in the chip
TIA
attached
  • STOCK SD2.zip
I just remembered that BIN file is probably from the original rev 1.1 SD2 chip, before the flex-fuel stuff was added with rev 1.2
not sure if that will matter at all, just be aware.
Yeah, looking at the ethanol percent and e85 spark adder you can see there's some gobbly-gook in there..... it's just old that's all.
the base tables are part of the flash image, so just re-update the powerlogger to restore them
But notice it says it does not affect the ve table, etc.
Okay I was under the impression that 1 didn't reset the be table but 2 reset it . I'm most likely wrong but that's what I was under the impression of
Made a blunder here in the spark and ve tables. How do I make them (the Spark and VE tables) go back to default?
Do I reflash?
