bird
- Feb 20, 2003
need some help with a freinds 86 gn, 60 turbo 63 exh housing, ported heads, 210/205 cam 3" downpipe, racegate. darn thing overboosts climbes slowly to 15 then jumps to 20 and keeps going. wastegate hole is ported to 32mm can go a little larger to35mm(down pipe opening is 35mm). would this make that much of a difference? tried everthing have the lightest(green) spring in the gate. even tried manually locking the valve open and it still overboosts, car is quick but not that quick that gate should be rated to 900hp. guessing this combo to be around the 500hp mark. were puzzled. please help. another freind suggested going to a bigger 83 housing? i dont think that should make a difference. should it?
