I have some white smoke that comes out of the tail pipe when engine is hot and I rev it up real quick.I was told it could be valve seals,pcv,or rings I have oil on the vacuum block port that goes to the pcv valve and was wondering if this is my problem how do I check to see if the pcv valve is bad??? my buddy says to shake it and if it rattles around then it is good...is this correct????mine is out now and it does rattle around...I am going to take off the up pipe and look in the throttle body for oil now...any help is great thanks in advance...
