I have a new motor with GN1 heads that has 600 miles on it. The motor runs really great... but at idle (especially after reving the engine), and when "letting off the gas", grey smoke wisps from the exhaust pipes. It seems to happen only at high vacuum, no smoke at all is seen at W.O.T. The engine does not appear to be using any appreciable amount of oil or water.
I took off the inlet pipe and the inside side of the throttle had a lot of oil on it. I temporarily blocked off the pcv vacuum line (I have 2 valve cover breathers) because that definately was one source of the oil in the intake... but even with that I still get grey smoke. I've driven about 75 miles since I did that, if oil got into the intake, I wonder how long it would take to drip down and burn away?
Do your GN1 heads smoke at high vacuum??? Any ideas would be appreciated. Paul
