87we410877
- Apr 5, 2005
Does anyone have a picture of the Diamond pistons? Im curious to se what they look like. Thanks.
SignUp Now!87we410877 said:Does anyone have a picture of the Diamond pistons? Im curious to se what they look like. Thanks.
III'S 87 GN said:here you go !!!
i have a new set of 30 over with rings if you are interested![]()
87we410877 said:Isnt that going to change my compression ratio? The TRW's i have the complete concave shape w/o the valve reliefs.
This is a custom one for 6.5" rods not for stock size rods they come bothe ways87GN_70GS said:
CTX-SLPR said:different style of dishes. The Diamonds, my custom 4.1L 3.995" bore pistons look identical, use whats called a reverse reflector dome type of a dish that lends itself, supposidly, to better chamber mixing but make for a potentially thinner piston crown. The stock style, TRWs in your case, use an inverted dome that creates more uniform piston heating and allows for a shallower total dish with the same volume and a thicker crown. Personally I love my Diamonds but any good quality piston is probably equally likely to work in a performance application, leave the knitpicking to the guys with full race jobs.
turbodave231 said:Here is a Diamond S2 piston. All the sharp edges polished smooooooth and glass beaded!
DR
Looks good. What did you blast it with? Looks very fine like wallnut shells.
