Pics of 6162 S cover vs E cover (Turbonetics)
TTA976
302
32
28
Nice turbo...That's the one I run. Spools very well and makes good power. If I was choosing Turbonetics , this is a turbo I would choose for a mildly modified 231 ci .
Excellent match of wheels
T- Type Tim
Vice Chairman
Jul 8, 2001
1,530
214
63
43
Chandler AZ
I liked the E cover 6162 was fun on the street and did well at the track ..... I’m really anxious to see what the S cover does
T- Type Tim
Vice Chairman
Jul 8, 2001
1,530
214
63
43
Chandler AZ
I finally got to make a 20 psi hit with this turbo after upgrading the fuel system. The old turbo lived around 25 psi, this one has a faster spool even with a base tune that needs more work. so far so good, and Cottons hooked me up at a great price. This thing definitely is moving more air!
Mr.Spool
4,282
553
113
love the tnetics stuff!it takes a pounding and the billet wheels with the bigger covers make alot of power for their size.i ran a billet 64 and 69mm turbos with the larger t series covers that do really need an angled iac.
JP112_89
1,028
43
48
That e cover has the T61 cast compressor wheel like the older 6131,6152,6176. The tnetics HPC 61 is forged aluminum billet.. Same thing basically... Both 6 blades ...turbonetics shaves the hub down.
I have this same turbo as op..tnetics hpc 6162 bb. Same comp and turbine wheel as the tnetics gtk 600. I like it.
  • Like
Reactions: T- Type Tim
Rockale
95
8
8
23
Decatur,AL
Sorry to hyjack, just wondering how much power can be made with the tnetics 6165?
JP112_89
1,028
43
48
The 62 turbine is a better match for the HPC 61 . Can't see HPC 61 being that much better the cast T61. T61 compressor wheel according to it's compressor map is good for 62#/min . 62 turbine is good between 65-70#min.
I personally think HPC 6162 is about the best match of compressor/turbine.
Mr.Spool
4,282
553
113
they make several 61mm comp wheels, if op has an hpc 61 that will outflow any of the others as that is their competition wheel.their stuff is underated from what i have seen so it is hard to get real answers unless you test yourself.should be a bad ass sreeet turbo with a mild motor or even a stock motor.i pushed there 62mm cast wheel and i would expect that hpc 61 to outflow it 10.4-10.6s@130 on the right car
JP112_89
1,028
43
48
I'm taking about T61 6 blade it was PTE GT wheel. They have a compressor map for it.
Op HAD tnetics 6162 which has the same comp cast wheel from PTE GT technology. He recently upgraded to hpc 6162.
Top Bottom
