once you cut the ears off the sides it pops inbetween the sides of the stock radiator , grind the one arm of fan that will hit the power steering box and push fans to bottom
use the bracket off the old fan , flip it over and turn it around and use it at the top to keep the fan inplace , the bracket holes will line up with the holes for the a/c hose studs , the long side of bracket will rest across the top of fans and you wont need to drill any holes in the fan or the bracket to keep the fan secure
on the fbody radiators you need to shave the sides down a little more but then they install same as with stock radiator
