I know this topic has been beaten, but I even called Kirbans tech support and they were not sure which one is the temp sensor. I understand it has one single green wire going to it and the wire should be taped since it wont be used.
My question is where is the thing? If I was facing the engine, it is just off center to the right (closer to drivers side)? Does the sensor mount from the top or does it mount in from the front? All the potential ones i see have a wire type harness that seems to snap on, but I cant figure out how to get them off.
And again sorry for posting this, but I did search the archives and came up with many different locations for the same sensor. Some said under the upper radiator hose, some said on the top, some said left, near passenger side.
My car is an 87 GN
My car is an 87 GN
