Here is mine from my blue car, you should find most of yours on it too
RPO RPO NAME DIVISIONAL RPO DESCRIPTION
AM6 SEAT FRONT SPLIT BENCH
A01 WINDOW TINTED ALL SHADED WINDSHIELD
A31 WINDOW POWER OPERATED, ALL WINDOWS
A90 LOCK CONTROL RR CMPT LID.REM CONT ELEC RELEASE
BC1 ORNAMENTATION INTR, I/P
BF2 COVERING FLOOR CARPET, DELUXE
BS1 INSULATION ACOUSTICAL PKG
BY1 ORNAMENTATION EXTR EMBLEM, BODY,VAR3
B51 MOLDING ROCKER EXTRA WIDE
B85 MOLDING B/S EXTRA BRIGHT
B93 ORNAMENTATION EXTR MLDG,DR EDGE GUARD
B94 ORNAMENTATION EXTR EMBLEM, BODY, VAR 1
CF5 ROOF SUN, GLASS, SLIDING, ELEC
C49 DEFOGGER RR WINDOW, ELECTRIC
C60 HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS
D68 MIRROR O/S LH & RH, REMOTE CONTROL, COLOR
D7I GEAR GEAR, SPEEDO DRIVEN (D7I)
E5Z ADAPTER SPEEDO----------- DELETE
FE3 SUSPENSION SYSTEM SPORT
FFL FLINT MICHIGAN FISHER BODY PLANT 1, BOC
GMD ALL GMAD PLANTS
GU6 AXLE REAR 3.42 RATIO
G80 AXLE POSITRACTION LIMITED SLIP
G87 RING GEAR 8.50 INCH
J41 BRAKE SYSTEM PWR, FRT DISC, RR DRUM, CAST IRON
J50 BRAKE SYSTEM PWR
K09 GENERATOR 120 AMP
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
LC2 ENGINE GAS, 6 CYL, 3.8L, SFI, V6, TURBO, HO
MW9 TRANSMISSION AUTO 4 SPD, THM 200, CONV CLUTCH
MX0 MERCHANDISED, TRANS AUTO PROVISIONS, O/D
NA5 EMISSIONS SYSTEM FEDERAL, TIER 0
NP5 STEERING WHEEL LEATHER WRAPPED
NQ5 CAP STRG WHL HORN
N33 STEERING COLUMN TILT TYPE
N89 WHEEL TURBO ALUMINUM
P0N ASSEMBLY PLANT PONTIAC MICHIGAN
QYZ TIRE ALL P215/65R15/N BL R/PE ST TL HWY
T47 COMMERCIAL BODY PROVISIONS, UNION CITY BODY COMPANY, STEEL
T82 HEADLAMPS CONTROL AUTOMATIC ON-OFF
UL5 RADIO DELETE
UX6 SPEAKER SYSTEM 2. CUSTOM
U23 CLUSTER INST. TRIP ODOM
U75 ANTENNA POWER, RADIO
VD6 BUMPER PROVISIONS FRT. ALUMINUM
VD7 BUMPER PROVISIONS RR. ALUMINUM
VK3 LISCENSE PLATE FRONT FRT MOUNTING PKG
V73 ANTENNA FIXED
W05 REGAL LIMITED COUPE
YR1 SEAT FRT CUSTOM
YS1 SEAT RR CUST
YT1 BUILD UP DR & QTR
YT9 OPTION PACKAGE FISHER FURNISHED PARTS
Y56 MERCHANDISED PKG GRAN TOURING
27D TRIM COMBINATION CLOTH, DK BLUE
27I INTERIOR TRIM REGAL BLUE (I) (98)
279 TRIM COMBINATION PLUSH SEATS?
31Q MOLDING COLOR BRIGHT GREEN
31U PRIMARY COLOR EXTERIOR, GREEN/BLUE(96)
6YX LH FRONT SPRING
7YW RH FRONT SPRING
8PZ LH REAR SPRING
9SJ RH REAR SPRING
Blue car
