Ok, here we go. I got my car with 63000 miles on it a month ago. Great condition, perfect interrior, the guy kept a log book of everything. It ran GREAT until NOW. 1st. I started to here a grinding, shrieking, swirling, rubbing noise under the wood. Loud enough to hear in the car. It sounded like a heat shield or something is rubbing? It ussually went away after the car got warm or I started to drive it. Now it back and really loud at idle and driving. I cant figure out where its comging from.
2nd My fan relay delay sensor is bad, so I unplugged it. Ran the car for a day and it was fine. But today while its still unplugged I got onto the freweway and noticed teh car was missing and RPMS started to go down. I looked at fuel pressure and It was LOW. Under 30. I gave it some gas and it shot back up. Then it stalled and I had to pull over to teh side. Turned the car off and tried to crank it again. Wouldnt start but did crank. I unplugged the battery then plugged it back in and started the car fine. Drove another 5 miles with no problems.
So could driving without the fan relay plugged in have casued it or should I start to worry about a bigger problem. 2nd what on earth could that grinding noise be???? I know my explanations are hard to understand but I am really frusterated right now.
