fuel pressure too high? Intake leak somewhere making ECM compensate? Crapped out injector(s)?
Any particular cylinder?
You could try a power balance test: Start engine and pull each plug wire off (I loosen them before I start the engine) while it is running, there should be a very noticable difference with the wire removed, if not there is trouble with that cylinder. Unless you knew that procedeure...
Bill
