PLX 300 Tuner Edition Air/Fuel Gauge
JP112_89
Hi, for sale PLX 300 Tuner Edition.
Works great without any issues. Purchased it from PLX in 2014ish...
It's solid box built with aluminum. Not a cheap wideband, paid $325. 100% of the same features as the PLX Air Fuel Ratio Sensor Module with a built-in 4 digit display. It is fully compatible with other PLX iMFD gauges and can be daisy-chained with other PLX Sensor Modules. Fuel Select (Gasoline, Diesel, E85, Methanol, Ethanol, CNG, LPG, Lambda Mode).
Asking $95 shipped to lower 48. Thanks
So the display for the AFR is on the little box?
What size is the display box? Will it fit on top of the radio/AC controls area?
So you can switch between E85 or gas and it will automatically calibrate the readout for you? Or how does it display each fuel differently? ...basically what happens to the unit when you select e85 fuel vs gas?
Never used those features but it's supposed to... I had it mounted below my dash, above my speedometer...wired ran thru dash...looked great. 10" cable tmk.
