Poly Crossmember mounts, poly bump stops, complete all new blazer brake setup, new tie rod sleeves
V6UnderPressure
The Artist FKA Scott4DMny
I have a few things for sale. LOWBALLS WELCOME!
Full Blazer brake setup w/gold painted calipers: Brand new Rotors, Remanufactured Calipers/PABS painted with G2 Gold Paint, New Bearings with custom CNC machined ABS plug delete plate, Black Powdercoated spindles, Bearing Shim (dust shield delete), and the brake line bracket everyone always forgets about. Only thing this needs is a set of the rubber bushings installed for the PAB's. $350 shipped obo.
Brand New HRPARTSNSTUFF Performance Red Performance/Race Poly Crossmember mounts. $75 shipped obo
Brand New in the box Hotchkis Tie Rod Sleeves $40 shipped Firm
Brand new Hotchkis front control arm bump stops $10 shipped Firm
Here are the photos:
I'll take the Hotchkis tie rod connector. PM payment info please.
Sorry about a dumb question. How is it beneficial to upgrade to the Blazer set up?
The blazer calipers are dual piston calipers and much larger than the stock single piston caliper. The rotor is also I believe a 1/4 inch larger in diameter. It also uses a sealed bearing as opposed to having to pack the stock ones etc. The blazer setup is also a direct bolt in upgrade that keeps the stock suspension geometry.
