copgn, a buddy of mine recently ran 11.93 in his TTA. it has ported stock heads, 210-205 cam, 3 inch DP, alky, custom chip, and stock turbo @ 16 psi plus small stuff like fuel pump and regualtor and KN. that was with a 5 lb launch, low timing, and BFG Drag radials i believe and his car has a 12 bolt 3.73 rear which meant he had to shift into OD before the finish line. the alky was used b/c he said the stock turbo was well out of its flow range and was heating the air so bad he had to use the alky. a more efficient turbo may be able to keep up with the airflow and alky may not be needed. he is on the board. his name is BM Computer Src.
