Posi Rear or Not ?
dsa87gn
Here goes, car has the g-80 option, but I think it may have been changed out for an open ended.
I had been thinking the clutches were shot, but not so sure anymore. I did a quick fluid change but to be honest didnt even poke around in there since I know squat about rear ends anyway.
Symptoms...
Stand on the brakes/gas and it will fry the pass tire only..
Stand on brakes/gas in reverse fries the drivers tire..
Hard accel on a left turn definitely spins the dirvers tire.
Throttle stab from a light will sometimes spin both.
Jack up the car in park, tires spin in opposite directions.
My confusion/ignorance is if its not posi why does the drivers tire spin
what do you guys think ?
If the tires spin in opposite directions I believe that means you have an open rear. Correct me if I am wrong.
